In a bid to improve my playing recently I've been watching a fair few youtube vids. One thing I've noted is that almost everyone holds the pick with a closed hand. ( Middle, ring and little finger tucked in, if that makes sense).
I've been playing for 35+ years but have always had an open hand and used my little and ring fingers as a kind of anchor.
I'm completely self taught so just did what came naturally at the time and have never been shown any other way.
This has got me wondering if this has held my playing back in some way ? Does it make a difference?
FWIW - I play like you. Open right hand with pinky anchored below the high E string. But that's only when I'm arpeggiating or playing single note lead lines. When I'm strumming forget about it - my whole right arm is moving lol
* There is no one right way.
* There is one right way.
* There are some very wrong ways.
^ All four statements are true!
There may well be One Right Way for a given player in a given style - but of course your best way and my best way and the next chap's best ways are very likely all different.
I think the key here is that you have to look for the limitations of your chosen method. (Yes Virginia, all methods have limitations.) It may be that the limitations of your chosen method are not very relevant to you, and may not even be apparent (if your method suits your style especially well).
I held a pick like a pencil for 40 years. (With two fingers and thumb.) That's an odd grip but by no means unheard of - there is a certainly a number of famous players who do that. Just the same, while it gave me excellent speed and accuracy, I never, ever got consistent good, smooth tone and even volume. Tried and tried, practiced and practiced for many years. No dice. The only instrument I got good tone with and felt properly in control of was the bass - which I played with my fingers, not a pick.
Every so often I'd try to adapt to an orthodox plectrum grip, but I could never get the habit or feel comfortable doing it. Unlearning is really hard!
Eventually, I tried playing fingerstyle. No unlearning barrier there, I took to it like a duck to water. I have never looked back.
TLDR: if you want to change, try something really different. The benefit is that you can just learn it instead of trying and trying to unlearn something.
It’s made an improvement to my picking and has also helped if I go back to my old technique.
I use Planet Waves Black Ice 1.5mm, very thick and hardly any of the tip protruding.
Anchoring is ultimately counter productive- yes it took some time to learn how to play without it but I highly recommend that people do that.
Some people can make it work for them and ultimately there is no ''best' approach to anything.
I also went through the Troy Grady stuff- it was very interesting and by making a very small adjustment to my technique I was able to find 30 bpm for my speed picking.
Football is rubbish.
....ah, pick?!
