It's quite common to see recommendations for using hi cuts on IR's/ cabs when playing a modeller through an FRFR speaker but.......
....if an IR is a "capture" of a specific mic, in a specific position on a specific speaker in a specific cab, in a specific room, why should it be necessary?
Surely if a particular guitar speaker doesn't generate much over say 8500 hz, surely the mic can't capture a frequency that isn't there in the first place and therefore it wouldn't be present in the IR? If a real world speaker was too bright, you typically adjust your tone controls on your amp/guitar/pedals etc, or change your speaker..
I mostly use York Audio IR's in both my Fractal and HX Stomp and I'm sure I read somewhere that Justin from York Audio suggested NOT using hi cuts.
I'm just trying to understand if I'm missing something fundamental, so curious to ask the Hive mind...
I've concluded that it doesn't matter. People are very probably wrong about why the things they do work for them, but if they work then happy days.
High and Low cuts on cab blocks....at the end of the day it's just EQ isn't it. Do we ever really hear the raw sound of a SM57 on a speaker without any EQ, either live or on record? And of the sounds we do hear live or on record, would they be pleasing to the ear on their own for practice? The cab block is just a convenient place to do it for me.
When sound is reflected the reflection and original sound will be out of phase. The higher the frequency the more likely it is that some degree of cancellation will take place.
IRs are generally close mic’ed to avoid picking up reflected sounds from the room. Lack of absorption and cancellation mean that close mic’ing is going to give a brighter sound than what you’d hear a metre or so away.
https://www.youtube.com/live/7YJMVwcF4SQ
Therefore, by cutting anything over say, 8,000hz, you are fundamentally changing the core tone of the speaker.
I get that we don't listen to a guitar cab on full tilt with our ear right on the speaker (which is essentially what a mic is doing) so the sound we actually hear in a particular space is influenced heavily by the environment in which we're hearing it.
In the "real world" if you are playing an un-miced cab, you adjust "your" tone via amp and guitar and if that doesn't get you what you want, you might consider a different cab/ speaker.
Of course, when it comes to micing a speaker, that brings a shed load of other factors into play.
If , however, you have spent a long time honing "your" sound (likely dialled in directly and not through a miced cab) wouldn't you want it to be replicated as closely as possible?
Why try polishing a turd when you could choose a different speaker like you would outside of the digital domain?
A modeller provides a myriad of ways to "EQ" the sound yet the hi/lo cut on the "cab" approach seems the most often mentioned and I'm still no closer to understanding why that is so.
I really should get out more....
Ebay mark7777_1
I don't know the exact slopes, but HX is similar. The cuts in the cab block are less severe than the hi/lo cut eq block.
