Never did like physics....
https://www.google.co.uk/search?q=4x12+series+parallel+x+pattern&hl=en-GB&source=lnms&tbm=isch&sa=X&ei=Tsc9UpGjIKfX0QWuu4GoAw&ved=0CAcQ_AUoAQ&biw=1366&bih=643&dpr=1#facrc=_&imgdii=_&imgrc=TnXHjRsu1pdFQM%3A%3Bbd4mqE_ziKqNLM%3Bhttp%253A%252F%252Fi5.photobucket.com%252Falbums%252Fy190%252Fvintagekiki%252Fdownload%252FS-Pwircab.jpg%253Ft%253D1209149997%3Bhttp%253A%252F%252Fvintageamps.com%252Fplexiboard%252Fviewtopic.php%253Ff%253D1%2526t%253D72913%3B1161%3B810
Series Parallel seems the way to go, am I right in thinking the above link is right? The Series Parallel X-Pattern Option on the right of the photo?
I'm not going for a mega heavy sound. Cab is to be used with a JCM900 so its pretty hi gain but not modern metal. Just thought i'd give this a try - 4x75's lacks mid range, 4xv30's has too much mid and sounds really 'boxy'... This seems like a feasible solution!
Didn't realise the difference between Series/Parallel and Parallel/Series made a difference tonally? I get that I should have a pair of v30's and a pair of 75's wired together, but how does it make that much difference whether they're in parallel or series when ultimately the end result is the same?
Don't doubt you (ICBM - fountain of all amp knowledge as far as i'm concerned!), just intrigued more than anything!
It does, but far less than the difference between the speaker types.
Right I think I'm getting it (really do hate wiring)
So basically (if I put the speakers in an X Pattern - V30 top left and bottom right, T75 opposite), I'm wiring two series pairs consisting of 1 v30 and 1 t75, then wiring the 2 pairs together in parallel?
Right, I think i'm starting to get it now...
Don't suppose you've got a diagram or anything? There are millions online, all ever so slightly different.... If I've got a picture, I almost certainly wont 'feck it up... If I follow instructions then I probably will!
I'll give it a go, thanks again
Really appreciate your help... Who needs music radar
