Boss katana - presets and switching?
John_PJohn_P Frets: 2758
Just thought about getting one as a backup that can live in the van - can you save a few presets and flick between them with a footswitch?
  • PALPAL Frets: 569
    Depends on which model. If you want a 50 watt then it needs to be an EX model then you can use the Boss GA-FC EX Foot
      Controller. There were two types of foot controller so you need to do some homework. If your buying the Gen 3 amps it's
      a lot easier. Hope this helps.
  • John_PJohn_P Frets: 2758
    Thanks - I'll have a look at the footpedal and check which models it matches.
    I've got a couple of midi pedals - do any of the katana's let you save 4 presets that can be selected over midi?
