If I use a capacitor and a resistor in parallel (rather than series), I understand that it can influence the taper of a potentiometer.
That would be a desirable thing, since I would like to change my 500kΩ audio taper pots (Les Paul) to behave in a more linear fashion.
Calculation:
So at the mid-point ('5' on the dial)
Resistance would be 10% or 50kΩ (450kΩ on the other side of the pot)
At the mid-point (at '5')
The 330kΩ resistor is in parallel with the side that has 450kΩ resistance
Effective pot resistance would be 198kΩ (302kΩ on the other side of the pot)
(1/R = 1/450 + 1/330)
So the taper would be somewhat closer to linear...
I guess a 450kΩ resistor will mathematically make the pot linear. But would that compromise the efficacy of the Treble Bleed circuit?
What say you?
Your maths seems to be on point in regards to the effective pot resistance, I would say that's as close to linear as you'll get while mostly negating any unwanted side effects.
A log pot has 10% of its resistance in the lower part of the track at half turn - ie 50K, for a 500K pot. A linear has 50% - so to turn a log into a linear, you need to reduce the upper part of the track to 50K as well. This would need a 56K resistor in parallel with the remaining 450K - the problem with that is that the total resistance to ground is now only 100K at half turn, which will dull the tone a lot.
Now, the good news - for a 30% audio taper, it’s 150K at half turn, so you need 262K in parallel with the remaining 350K, which is a much less drastic change in load, only down to 300K at halfway.
I’m sure it’s not a coincidence that my favourite treble pass values are 680pF in parallel with 220K - that’s not far off a linear taper for the low-end, but with a treble boost to offset the slightly duller tone as well as the cable capacitance.
Yes- but I'll have to take out the log pots from my Les Paul (with all the push-pull wiring faff), install linear ones and re-wire.
Installing a treble bleed (if it would have worked) would have involved much more 'superficial' surgery
It’s a bit like those ancient Greek temple columns which have a curved profile, intentionally so that they look straight when you’re standing at the bottom of them .
It will work. Try 220K and 680pF… you can thank me later .
My aim is to have a wider and easier range of ‘blend tones’ in the middle position between 5 and 10 on one pickup (the other pickup being on 10).
The taper has changed very subtly - and the treble bleed / pass works really nicely…
…and now I’m getting a nice range of ‘blend’ tones between 7 and 10 on one pot, the other one remaining on 10. (Previously it was between 9 and 10).
