My singer has been having intermittent problems with his set up.
He is using a variax 700 and a pod hd500. During one gig the volumes were jumping all over, very quiet then mega loud - seemed to be cured by powering off and on again. Then the next week it did the same but also stopped recognising the guitar on the input list. He tried changing cables but no difference, then the 2nd time he turned off the power, it reappeared when he powered it up.
He's going to contact line6 this week but I wondered if anyone had come across anything similar?
He's not very techie so I'll post something on the line6 forum and see if anyone there has had similar issues.
The other thing to check is that both the cable and the output socket (RJ45) are sound. Intermittency here can cause similar issues.
Line6 can repair them for you, if wanted/needed. Or you may find an independent who can do it for you.
Good luck
