The MJW Twin is a two-channel preamp, mated to the Goldstar, Roadstar or Electra power amps, giving you a choice of 10, 18, 30 or 50 Watts. Each channel has its own 3-band EQ, so it can be set up optimally.
The clean channel is based on the classic 'Blackface' circuit, so it has the chime and clean headroom that those amps are famous for, but will still crunch up at the top end for snarling country and blues.
The overdrive channel has 4 gain stages, and takes over where the clean left off, going through a classic 70s crunch, all the way up to a full-bodied rock roar with plenty of sustain and harmonics.
All-in-all, this is an ideal package for the pub/club guitarist who wants the flexibility of another channel, in a light and compact amp.
Main features
Output: 10-50 Watts
All valve: Yes
Valves: 3 ECC83s and either 1 6L6 (Goldstar Twin), 2 6V6s (Roadstar Twin) or 2 6L6s (Electra Twin)
Controls: (Clean) Volume, 3-Band EQ (Overdrive) Gain, volume, 3-band EQ
Size: 53cm (w) x 21cm (d) x 24-26cm (h)
Options
Power Scaling, Effects loop, digital reverb, valve/spring reverb, Roqsolid cover
Using hand-wired, turret board construction methods, the amp is available as a head, or a 1x10 or 1x12 combo.
Is mail an option?
interested in any trades?
My understanding from previous sales is that it is 10w
Hopefully previous owners might be able to chime in
I have had a few single 6l6 amps and when they were measured , they came in at 12w as @TheMarlin kindly suggested but I haven’t had this goldstar measured
Apologies at this point not keen on postage and would like to try and get the hard cash initially as opposed to trades at this point
powerscaling definitely does work
My experience is that it is variable across range not just a few preset intervals
again I will hope previous owners will chime in regards this with their experience which is likely to be longer than mine
to be brutally honest I never used it much past about 10% and sometimes not at all as the MV did all I needed
partly why I prefer collecting so buyer can test all these things out to their satisfaction
cheers
The drive channel with the amp turned up loud is superb, powerful EQ so covers a lot ground, from clean to sharp searing leads. Superb amp.
