Actually, the taller saddles with deeper grooves on the far-east ones are arguably *better*, as they reduce the problem of strings contacting the back edge of the bridge or jumping out of the grooves… but they do look less elegant. (And are a slight risk to your hand, as they can be quite sharp!)
It’s probably arguable that they sound different too, although it’s hard to directly compare since they’re not interchangeable due to the post size difference.
A bit like chewing up the stopbar slots by using the wrong tool - any screwdriver. The right one is a coin, they were designed like that on purpose! That’s why the slot has a curved bottom.
I use faber bridges now which are nicely made and have notched saddles
This isn't a one is better than the other post just my own preference.
(formerly customkits)
You can see the insert in the bottom pic with the slot head screw adjuster screwed in.
this is the big insert style you often see of far eastern guitars
This is the traditional ABR1Gibson version, screwed straight into wood
and there is also a Gibson Nashville version with a smaller insert
Instagram
