Running your Amps off-grid
57Deluxe57Deluxe Frets: 7385
The desire to secrete myself away in a remote spot and immerse myself in my music away from the daily nonsense is overwhelming right now. However to achieve this means compromise like being off-grid for all your services, so what systems would be viable to be able to run your amps your usual ancillaries and of course your domestics?
<Vintage BOSS Upgrades>
  • BillDLBillDL Frets: 8688
    Some young transient people on less than minimum wage working shifts and furiously pedalling cycling machines fitted with powerful dynamos?
  • 57Deluxe57Deluxe Frets: 7385
    Treadmills could actually be reinstated as they were in Pentonville Prison in 1800's
  • guitargeek62guitargeek62 Frets: 4333
    Surely the simplest option is something like the Boss Katana Go, and a pair of headphones?
  • OilCityPickupsOilCityPickups Frets: 11492
    edited July 25 tFB Trader
    Steam powered off grid generator ... perfek! Runs on anything that burns ...
  • MaxA867MaxA867 Frets: 69
    According to a cursory Google search;
     The amount of electricity you can generate using a pedal-powered generator depends on a number of biological factors, like your age and fitness level, as well as the efficiency of the generator you are using. An average person capable of producing a sustained power output of 100 W can expect to generate from 31 to 74 W, depending on the efficiency of the generator system.”
    So you should be fine with an AC30, or a Deluxe Reverb. Provided you can pedal and noodle at the same time.
  • springheadspringhead Frets: 1683
    “ The amount of electricity you can generate using a pedal-powered generator depends on a number of biological factors, like your age and fitness level, as well as the efficiency of the generator you are using. An average person capable of producing a sustained power output of 100 W can expect to generate from 31 to 74 W, depending on the efficiency of the generator system.”
    Dunno, I reckon you’d struggle there. In the AC30 the EL84’s will be pulling about 20W just for the heaters. Another half a dozen watts for the ECC83’s.  It’s going to be less than 50% efficient so over 60W to make 30W out and it’ll be doing a good chunk of that all that time as the valves will be biased at a fairly high percentage of max dissipation.  Give Mark Cavendish a call, see if he’ll come and peddle while you play!
  • snowblindsnowblind Frets: 536
    Portable nuclear isotope generator.
    Or a THRII plus one of those solar panel car chargers to keep it topped up. Lithium motorcycle battery for your pedals. Easy.
    Old, overweight and badly maintained. Unlike my amps which are just old and overweight.
  • blobbblobb Frets: 3224
    You might need one of these....
    Alien Explorations Alien The Space Jockeys seat references the
    Feelin' Reelin' & Squeelin'
  • KittyfriskKittyfrisk Frets: 20308
    So you want to secrete yourself away in a remote spot & make amplified guitar noise?
    Hmmmm... OK.
  • digitalscreamdigitalscream Frets: 27830
    Best option is to buy gear that's suited to the task. A 1W amp will be way more than enough for home volumes - that can run off a solar + battery + inverter system without any trouble.
    Pedals can be run from a USB C power bank into a Harley Benton isolated PSU (for example - mine takes 12V, which a USB C PD power bank can put out). Get a solar one, and it's free.
    And, if you use something like a ToneX ONE on your board, it can also run into headphones.
    <space for hire>
  • Secret_SamSecret_Sam Frets: 314
    edited July 25
    Petrol generator and a very long cable so your amp doesn't get drowned out by the racket it makes.  That's the standard at Afrika Burn, which is in the middle of a desert. Not the greenest or most portable of solutions, but it works.
    The generator can provide lights, device charging and ice makers.  However, boiling a kettle requires about two kilowatts, so you will need gas for cooking unless your generator is truck-sized.
    If you are very off grid, wood for a campfire, barbecues and water heating (unless you like cold showers).
  • p90foolp90fool Frets: 32356
    Buy an acoustic guitar.
    You can burn it to generate power :D
    7reaction image LOL 0reaction image Wow! 0reaction image Wisdom
    Ah fair enough, perhaps downgrade to a Princeton or an AC15.
    To be fair I would 100% watch that as an olympic cycling discipline  - what’s the beefiest amp you can power with a pedal generator and for how long? The heavyweight category being a 200 watt Marshall Major.
  • Dav275Dav275 Frets: 316
    Perhaps something like this?
    https://www.amazon.co.uk/Panana-Electronic-Generator-Adventure-Emergency/dp/B0C1SQNR1L/ref=sr_1_3?sr=8-3
    Could add a solar panel for recharging, if you needed longer duration.
  • PolarityManPolarityMan Frets: 7459
    just run an extension lead from the neighbours
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    There’s a video somewhere, YouTube, of one of the world class cycle sprinters powering a toaster! He was flat out for long enough to toast a slice of bread.  I think they push upto a kilowatt in those final sprint finishes.
  • EricTheWearyEricTheWeary Frets: 16622
    Have a look at solar power battery banks, Jackery is one the brands I know. Not necessarily a cheap option but once you've invested a few hundred quid you could power an amp for a while off the power of the sun.
  • HAL9000HAL9000 Frets: 10022
    Or upgrade to a Lance Armstrong for enhanced performance.
  • MikePMikeP Frets: 66
    I can run my amp off a second hand uninterruptable power supply for computers and data centers etc for maybe forty minutes?
  • Power-BeefPower-Beef Frets: 214
    Some kind of solar system by way of a Jackery solar panel and battery pack, powering a Katana Mini, and may be a Helix One? At least that's the way I am most likely to take if I were to find new accommodation deep in the woods, in the form of a log cabin. I haven't bought the Helix yet. No spoilers.
    Does anyone know of such a property? What's the parking like? Neighbours? What kinds of self defence will I need? Are there raised beds for growing food? What about a log fire?
