I've never really bothered with switchers before, but I'm now in a band that covers a lot of ground and I've realised I'm doing more tap dancing than I want to, so thought I'd dip my toe in the waters of pedal switchers. I've been doing some reading up and research, but was hoping for some more real world based opinions.
I'll have to build a new board around whatever I decide to go on, but the current board is as follows:
Tuner > Lightspeed (always on) > TS > Protein > Revival Drive Compact > Amp
In the effects loop I have:
Flashback > Hall of Fame (always on) > Spark Mini boost
I'd be looking to replicate the same set up, and utilise the separate/split of the Protein via the TRS option. Also, I'm looking to swap the Flashback with a Keeley Halo in the near future, so that needs to be a consideration.
Any ideas what switchers could help me with this? I'll be needing the ability to store pre-sets and change routing options etc.
I will say that I'm not flush with cash, so probably not at the GigRig level of switcher, alas.
This week's procrastination forum might be moved to sometime next week.
Only the ES-8 will let you swap the order of pedals though.
Since I started using a switcher I haven't looked back. There's so many options.
I have used my Duellist with the TRS to mono cables into two separate loops.
The FXL8 Pro is great, but you're limited to 4 into the loop, 4 in the front and you can't change the order.
I also have a Boss GT-1000 which is a multi-fx and amp modeller if I decide to go direct and not carry an amp with me.
Here is mine. Just got the Line 6 M5 so I need to learn how to control it with Midi.
There is video on YT of a guy who controlled his Halo via the ctrl outlet and a TRS cable might be worth checking out.
I have also seen people use the four cable method with the ES8.
flanging_fed “
Guitar -> Lightspeed (always on so no loop required) -> ES-5 in -> LOOP 1: TS -> LOOP 2: Protein 1 -> LOOP 3: Protein 2 -> LOOP 4: RD Compact -> LOOP 5: To amp input / fx send -> Halo -> ES-5 out -> HoF -> Spark -> FX return.
It's not perfect- you'd have to switch the Spark boost on and off separately (although the ES-5 can boost the output volume and as such might make the Spark redundant)- but it might serve.
If needed, you can add a second loop switcher device controlled by the ES-5. Bright Onion makes a dual loop controlled by a TRS input that could run off one of the ES-5's TRS outs. Alternatively, there are small MIDI controlled switchers with more loops. Still cheaper and more compact than an ES-8, although obviously you can't change the order of the loops in your "slave" switcher.
