Hi all,
I love my Tele. It's a classy candy-apple-red, double-bound affair with a roasted maple neck, ebony board, great hardware, electrics and Klein pickups. When I built it, I tried to get it as high-spec as I could afford. The one compromise I had to make at the time was the body: it's heavy as all hell. So I'm considering replacing the body with a lighter one.
So the question is: what's the best value way to reduce Tele body weight?
- A chambered (alder, basswood or poplar) body with a cap
- A roasted alder or ash body
What's likely to reduce the weight more?
It'll probably need to be one or the other (for financial/import reasons). For ref I plan for it to look exactly like my existing tele - so I won't be having any contours cut out or anything.
Thanks as ever...
it used to be possible to find swamp Ash bodies weighing around 1-1:5kg but you will need to search far and wide these days as light swamp ash seems to be harder to find.
probably worth weighing just the body you have and seeing what weights people are advertising some can give you the weight.
I have two electric guitars whose bodies are made from reclaimed old timber - one from Brasilian labourers' sheds, the other from a Colorado railroad bridge and out buildings. Both are extremely lightweight. Neither sounds exactly like a swamp ash T-style.
You'll want to be slightly careful though, as you can get up with neck dive if the body gets too light, and particularly if you have heavy tuners. My Cabronita is also a thinline and used to neck dive very happily when it had locking tuners. I switched for non locking and it got better. I don't have a weight on that one because it currently has a Bigsby but it was sub-7 for sure.
Happy to weigh my other thinlines this eve if helpful.
I'd go chambered alder, in my limited experience it might have firmer lows than poplar or basswood/sen.
I've got a paulownia shortie P bass that is only 5.7lb
https://kottracker.com/
1" forstner holes in a body remove approx. 25-30g each.
Obviousy the heavier the wood, the more each route/hole removes.
In this case, i would go with light weight wood
Instagram
But if the guitar is already heavy you'll probably save more than that just switching to a lightweight solid.
What's the current weight of the whole thing?
Bandcamp
Bear in mind that it won’t sound quite the same though. A standard Fender Thinline - which is only about 20-25% lighter - sounds ‘airier’ than a solid one. Even so, the PRS Hollowbody I had still sounded more like a normal PRS solid than I expected (or really wanted).
I’m not a fan of overly light woods, I don’t think they sound as good, and are usually weaker. (And I especially dislike roasted ones - edit having seen chris78’s post below, yes - I would say dull rather than dark.)
In my experience, roasting darkens the tone, chambering thins it
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
