It is a middy sounding drive, though - most middy ts sounding ones do have a blanket over amp effect, which is why they work best when the amp is a bit driven too.
More open, balanced sounding drives like the od-3, timmy, blues driver etc might suit you better.
I likes a BM into a dirty Marshall.
I find the "blanket over the amp" type thing, when the pedal is being used as a stand-alone, or if it's boosting a pedal.
I can't comment on an AC-30 as i've not tried a BM into one.
Combined with CH1 crunch mode it gives me great smooth lead tone and with burn mode on CH2 it still retains clarity and is very quiet too considering the amount of gain applied. And that's still with the same settings on the pedal meaning it actually added another two useful channels to my amp.
Every other mid-priced drive pedal I've tried with the express couldn't do that hence why I'm a one happy fella
Agreed though (as I just said in another thread) if you actually want the TS thing, the CM2 actually goes a little too far into "transparent/clear" territory (at least mine does). )
