Prefixes
Phil_aka_PipPhil_aka_Pip Frets: 9794
edited November 2014 in Off Topic
a Lo broken into 10^12 pieces would give you a lot of piccolos, whereas 10^9 of them would give you a gigolo
breaking a phone into 10^6 pieces would give you quite a lot of microphones, whereas 10^6 of them would give you a megaphone
Presumably there are 998 more Millibands around, making up a complete Band (I only know about 2 of them)
10^3 whales is a killer whale
and finally 10^12 buls is a terabul
  • mike_lmike_l Frets: 5700
    Put that "special" cigarette out and have a lie down Phil.
  • I don't smoke :)
  • LixartoLixarto Frets: 1618
    You clearly should.
  • chillidoggychillidoggy Frets: 17137
    I don't know what you're on Phil, but it sounds like some good gear to me.
  • jellyrolljellyroll Frets: 3073
    Two icks make a dick.
  • imaloneimalone Frets: 748
    Peta Townshend, 10^12 lead guitarists.
    Attaboy, one billion billionth of a boy.
    Example, very ample.
  • BigMonkaBigMonka Frets: 1793
    I'm not sure if it needs a lol for being funny, a wow for putting in the effort of coming up with them, or a wisdom for knowing the correct prefixes for the different amounts!
  • I think it would be a picalo and a gigalo. So it stops being funny. In the same way that installing a speed limiter stops a fridge from driving too fast.
  • VimFuegoVimFuego Frets: 15844
    surely a speed limiter would stop the fridge from being driven too fast? I can't see how fitting a limiter to a fridge would stop it from driving too fast.
  • frankusfrankus Frets: 4719
    Of couse it falls down when a Tehran Fox is worth more than a Megan Fox ;)
  • Nah @CabbageCat, it'd still be picolo. It would though, as you say, be gigalo.
    Use Your Brian
    Yes it would stop it from driving too fast but it's not all that necessary because it wasn't going very fast in the first place because it's a fridge.
    Goddammit. You made me explain a joke. There goes the funnyship.
    And Mark, you get a share of the fury.
    do you know how sperated Cabbage cat is right now? He's exasperated.
  • holnrewholnrew Frets: 8207
    Does that mean he used to be asperated?
    My V key is broken
    Only if you're splitting hairs about the spelling. Puns are best heard
    A herd of puns?
    Lixarto said:
    A herd of puns?
    I heard of puns, too.
    What a way to cook up jokes ;)
  • johnnyurqjohnnyurq Frets: 1368
    So what is the accepted SI prefix for Juggalos?
    We need answers!
    We need answers!
    36DD ;)
