LOL 2
Wow! 0
Petepassion - Trading Feedback Discussions on theFretBoard
https://thmn.to/thoprod/606760
https://www.instagram.com/insta.guitarstuff/
Currently for sale:
Kemper profiler
Gibson Les Paul R9
Mesa speakers
But you can also send the sound with IR sim to FOH, or a recording desk.
The much vaunted Fryette Power Station does the same thing.
Forget attenuators.
You remove the connection between the amp and the speaker which is supposedly the important thing and then end up being powered by a solid state amp.
It's just adding a load more wires and complexity and things to go wrong. I'd either use an attenuator or just use a modeller, or get an amp with a sensible master volume of which there are loads.
I’ve tried a fair few attenuators, the best/most transparent being my Marshall Powerbrake and the Boss TAE.
I can get very close with pedals into a clean amp, but not quite as good. I’ve yet to use a gain control for drive with the master volume low that can better an attenuated cranked amp.
Here’s a comparison I recorded on YouTube…
https://youtu.be/KtFSClcPD8c?si=OjxtVhIu4Q8YElWU
Secondly, I’ve yet to hear a master volume equipped AC30 that sounds even remotely similar to a real Dartford Road amp for what I use it for. So no, it’s not an option. And modellers are a bit hit n miss in my experience - because they can’t produce the randomness of the real thing. And often they replicate sounds that are cliches rather than the breadth of timbre a real old amp can and will provide - it’s the sonic equivalent of Rory Bremner’s impressions… very impressive and very close but occasionally there is something that is exaggerated.
Im not interested in a solid state power stage. I’m interested in using some older kit in a studio setting where volume is an issue. And that is where this, the Ox, the Palmer et al are going to win over any master volume or modeller… *for me*.
The most important thing about a valve amp is the output transformer and how it responds in a non linear fashion when saturated and how it reacts (literally) to the reactive load of the speaker. If it wasn't for this we could just take a feed directly from a load resistor on the output valves.
So having a solidstate amp in the path is fine sonically and no different than what happens with listening back to a studio recording but may not feel like the real thing and here's another reason why. At high volume the amp and guitar become one instrument. There's a positive feedback loop and you can do all kinds of things with harmonics and clean sustained notes that you can't at lower volume. When I was running 2020 I used to run Marshalls and Fender Twins at insane volume in the live rooms to experience this. There's nothing on the market that can get you that because it's caused by the sheer volume of the amp feeding back into the pickups and resonating as one circuit. There's No means of experiencing that without using volume.
Totally agreed this is one of the reasons I see it as somewhat pointless to use something like a TAE
Loud amps sound good because they are loud not because they are running flat out. If you blast a modeller through guitar speakers and you are in the room with it, it sounds instantly way more like a real amp.
The whole thing about "power amp distortion" is largely bunk, most valve amps being run on ten actually sound mushy and a bit shit for most practical purposes.
In terms of the reliability it's one more box so it's more cables, one more thing to go wrong. (The chance of your rig failing is the chance of all of the components multiplied together so adding one more box is always worse)
I have been in the situation where I had a non MV amp that was a bit hair trigger in small venues, but I don't see why a TAE or a Fryette should be any better than a an attenuator other than the ability to add reverb which I don't really care about in a live situation or can be added via the desk.
1. EQ
2. Compression
3. Reverb
4. Delay
5. Solo boost
6. Multiple rig options
7. It can boost a smaller amp for live use.
Don't know about you, but I think that's a fair few advantages.
On the downside, for live work I would say it's relatively big and heavy, plus the 100w isn't as loud as I was expecting, but loud enough, so I think this latest model would struggle if used to boost a small amp for gigs and rehearsal.
Obviously it will be pointless to many people, including yourself, but it will also be a great asset for some.
My Powerbrake was great, but I went to the TAE as a cranked amp through a traditional attenuator can't be boosted volume wise.
I'm currently using pedals into a clean amp and getting a pretty good sound...but it isn't quite as good as when I use a form of attenuation, but the pedal route is less hassle.
Horses for courses as they say.
EDIT, I have used the Powerbrake, the TAE and also just pedals live and can say from personal experience that the attenuators work great.
If you don't like attenuators or re-ampers this product is not for you.
Currently for sale:
Kemper profiler
Gibson Les Paul R9
Mesa speakers
Good to see this one looks like it might have bluetooth - albeit Boss manage to implement that in their mid noughties add on way instead of doing it properly! :-)
I think the real challenge to all of these is the rapid improvement of modelling - both digital and analog options. For a more flexible / quieter solution when needed I now drag a UA lion to gigs rather than a big valve amp, big cab, and big attenuator. And tbh, I prob get better results.
