NBD - Just in from Japan - Greco Rickenfacker bass from 1974
NeilybobNeilybob Frets: 1973
Purchased via Buyee directly from Japan we have a Greco Rickenfacker RB-650 bass from 1974.
It does need a bit of work (I know a guy) but I got it for half the price that they are on Evilbay.
It needs a new bridge (the one on it is broken), neck pickup cover and trust rod cover.  In amazing condition considering it's 51 years old.
Anyone else have a Rickenfacker?
flanging_fed “
0reaction image LOL 11reaction image Wow! 0reaction image Wisdom
«13
  • FunkfingersFunkfingers Frets: 16187
    If you are not fussed about vintage originality, consider a replacement bridge by Hipshot or Babicz. These are not cheap but they do not curl up and die like the original design.
  • PeteBoPeteBo Frets: 251
    Nice one.! I've had a few in the past, a couple of the Hondo ones and an Aria version, I've had a couple of real 4001s long ago too, I'd love to get another but unfortunately even the fakers go for silly money nowadays  :(
  • That has the potential to be really nice :-)
  • prowlaprowla Frets: 5628
    Yep - I've had one or two fakers in my time, though not one of these.
    That's a 1st gen Greco, made at the Fujigen factory; they were also sold branded as Ibanez.
    I've got an Allparts bridge, which is a drop-in replacement, available.
    I'll ping you in the fakers group.
  • GoFishGoFish Frets: 4486
    Love the inlays and the rest too of course.
    How's the bridge p/u sounding?
    I reckon it'll be needing a bridge and strings before that question can be answered. :-)
  • AdeyAdey Frets: 3934
    That looks nice.
    There was an old Shaftesbury one on eBay recently, but the fretboard looked like it was coming away and not worth £600 because of it.
    If not a rude question, how much did you pay?
    No sound when tapped? That's a great start :)
  • An interesting point: those bobbins are pretty much universal in early(ish) Japanese pickups. Two of them can be found in some Maxon 6 string humbuckers ... and single ones hidden in Columbus etc 'single coils masquerading as Gibson size humbuckers'.
  • ICBMICBM Frets: 83526
    Which is presumably why making one pickup out of two of those works quite well.
    This one looks more like an early Thunderbird pickup, but presumably quite different inside.
  • It looks awesome!
    Actually more like a bass 'gold foil' inside  B)
  • NeilybobNeilybob Frets: 1973
    Following a visit to see @prowla ; last night it now has a new Allparts bridge fitted. Thank you Paul.
    Will plug it in (baby) and give the pickups a tap to see if they are alive.  The switch doesn't click anymore so I suspect that will need replacing also.
    flanging_fed “
  • ChoivertChoivert Frets: 175
    That looks ace - love the binding. Bet it will be lovely once all fettled.
    Pickups confirmed to be working after tapping them with a screwdriver and using my DigiTech Trio+ via headphones though the switch is very iffy because it doesn't click and it takes a few attempts to engage the bridge pickup.
    flanging_fed “
    That’s a result re. the pickups.
    The switch will have to go through.
    Did you manage to get the pickguard off?
    That's the next job on my list. Will have a look tonight.
    flanging_fed “
    The switch is probably one of the 1970s Japanese box type - it’s possible to take them apart and fix them, but they’re never really that good - it’s best just to fit a proper Switchcraft right-angle type like an original Rick. (Or one of the cheaper versions of one - maybe more appropriate to the bass.)
    Thanks ICBM. Will be definitely replacing it with a better quality one that's in Keeping the Rick theme.
    flanging_fed “
    I managed to remove 7 of the 8 pickguard screws but the last one won't budge.  Will have to entice it with a soldering iron another time. Typically the one that won't budge is at the bottom in the last photo, next to the volume pot.
    flanging_fed “
