Wanted: Router table, bandsaw. Maybe router too.
As per title. I'm in Newtownabbey.NI.
Posting me one is fine too.
  • ESBlondeESBlonde Frets: 3646
    Look on the interwebs, there are some good HOW TO vids to make your own router table that will be better than the cheap ones and as good as those costing 'undreds.
    Ditto looking at how to set up a band saw, the cheap ones can be usable and accurate but they need tweaking first. A bigger used B/S will likely yield better results.
    Sorry I can't help you with a supply though.
    Have a bump.
  • jd0272jd0272 Frets: 3871
    Sheet of MDF and some machine bolts to attach yer router to it. Place atop a workbench, clamp, one router table. Tis what I did, works a treat.
    Guides etc can be made as needed.
  • Honestly can't be arsed.
