Hey guys before I go wading in.
A few of the screws holding the (ply) speaker baffle to the cab of my H&K Duotone, have stripped their threads. There are longer ones on the sides. and shorter ones that go through the bottom of the baffle from the back into the lower lip on the cab.
Filling and re-drilling is something that is not going to work for a man with such a lack of resources and talent as I.
So I'm thinking of wedging some slices of matchstick in the holes, but I'm wondering is a dab of wood glue a good idea too.
Got to get it locked in there tight. It was farting and barking something terrible.
Thanks
Thanks for the reply @ICBM
I was only going to put a few bits of match stick in, but you reckon to pack it tight eh!
One more question though if I may. Will the wood glue bond to the screw making it impossible to ever remove them?
No, wood glue doesn't bond well to metal.
Awesome. You must be getting sick of wisdom's.
Thanks again and Merry Christmas.
Stock dowelling is not so good as you are screwing along the grain.
Either get the kit for a "crossgrain plug cutter" or bore the panel out to take a dowel across the hole*
But in this case go with ICBM!
*Standard practice for pipe organ stop slides.
Dave..
Thanks @ecc83
I will be gluing and screwing later today (if the Man flu will allow). I have learned something new again, as I never knew that a dowel should be cross grain.
Interestingly, the reverb was intermittent on the amp too. I assumed the plug sockets had lifted from the board, so bought a new cable with right angle jacks to take the stress off them. When I opened the chassis though the joints were good. It took me a while to work out that what I'd assumed was an omitted resistor, was rattling around trying to short something out. It was perfectly formed and clipped, but had soldered on the very bottom of the leg, so that it had been standing proud of the board.
Don't know how it passed the notoriously efficient German QC procedures.
