Instagram
Instagram
they are all temporarily taped off at present whilst I did the mock up.
the on-on-on, are connected straight across on the underside - I will upload a pic later. nice to know the diagram is basically sound at present. I'll have to hunt down the hums I have; probably a dodgy solder joint
Instagram
I'll mount them all properly next and see what I get.
Here you can see the original tail piece and scratchplate holes filled in - don't seem to be able to remove the bridge posts at present
And here's a mock-up of what the switches will look like - thought it would be easier to solder up out of the cavity. Note each pot with it's on-off and splitting switch - hopefully in the guitar they will look better spaced....
Final rub down is in progress then it's off to be primer/filled before colour application
Good to see a nice long tenon too. Neck join is the weak point of this design but it looks like they have done all they can
Instagram
Zoot indeed
Looking good !
Feedback
Taking the SG in to throw some topcoats at it this Friday - apparently I will be spraying it!!! I thought mates in the profession would do it as a favour lol. Anyway, looking forward to having a go at the proper spraying now - always fancied it.
Hopefully the next update will be with photos of the coloured axe, with only reassembly left to do Here's to hoping!
