Moments of stupidity
I finally got round to reinstalling the humbuckers in my PRS tremonti SE over the weekend. I had actually screwed them in and fed the wires through ages ago, but I didn't have my soldering iron to hand. To make sure I connected the right pickup to the right volume control, I stuck a bit of masking tape on the neck pickup and on the neck pickup wire so I knew which was which when I finally got round to soldering them in.
I think you can guess what happened next...
  • speshul91speshul91 Frets: 1397
    you soldered neck to bridge?
    You take the cake :)
  • SassafrasSassafras Frets: 30357
    Don't worry, we all have moments of extreme stupidity, at least, I do and it seems to get worse as I get older. Far from getting wiser, I seem to be becoming dumber.
  • Axe_meisterAxe_meister Frets: 4858
    I remember wiring up a whole set of new UPS boxes in a small computer lab we had.
    Two week later we had a major power fault. Had a quick look in the room saw the LED on the monitors
    were on an walked away thinking all is ok. Power should last a few hours which it did.
    But I'd managed to plug all of the monitors into the UPS systems and the servers into the normal wall sockets.
    doH
    Hey, at least the damage is reversable, unlike the time when I went to pick up a screwdriver and whilst bringing it towards the screw I was screwing in I manged to catch the tip of it on the guitar body and put an inch long gouge into an otherwise immaculate finish.  #-o
  • mike_lmike_l Frets: 5700
    That's called going senile...........
    I did wonder what was happening to me. Thanks for putting me straight. As long as it's nothing to worry about.
