Would love a new distortion pedal!!!
bingefellerbingefeller Frets: 5723
So guys, I'd like a new distortion pedal but not sure what to get....any ideas?
I like the tones of Nuno Bettencourt, Steve Jones, Warren DeMartini, Michael Schenker, EVH....
I just have a Roland Cube Lite (not ideal I know) as an amp and only play at home.
«13
  • JAYJOJAYJO Frets: 1533
    If your interested ive got a Blackstar dist you can have for £50 delivered.
    Or a Boss os2 (mint) ie o/drive/dist pedal. £30 delivered.
  • mike_lmike_l Frets: 5700
    Blackstar HT dual
    Hardwire tube overdrive
    Marshall Jackhammer
    Just for starters
    i've had the Boss OS-2 before and it is good but not what I'm after.
    mike_l said:
    Blackstar HT dual
    Marshall Jackhammer
    Just for starters
    Is the Hardwire high gain?  What would the gain levels be comparable to?
    mike_l said:
    Blackstar HT dual
    Marshall Jackhammer
    Just for starters
    I use it on the "Classic" setting and sound wise it's pretty much like a Marshall Guvnor (Mk1). When I get round to making up the 80's rock board that'll be there for rhyth settings. Leads shall be from a Hardwire Tube Distortion on the "Modified" settings which is higher gain. Both are really good sounding pedals.
  • SassafrasSassafras Frets: 30320
    Rat or Way Huge Fat Sandwich are the only ones I use now after having tried dozens of other pedals that didn't quite do it for me. There are loads of different tones in those 2 boxes.
  • IanSavageIanSavage Frets: 1319
    I've got a slightly-gigged Jackhammer with box you could have for twenty quid plus whatever postage if you wanted.
    My old one?
    Good deal on this. Good pedal too.
  • MattFGBIMattFGBI Frets: 1602
    I bought a Rowin one the other day, it's great.
    This is not an official response.
    contactemea@fender.com
  • d8md8m Frets: 2434
    DS-2!
  • EricTheWearyEricTheWeary Frets: 16372
    a distortion pedal named after Black Country for having an argument. Makes sense.
  • EdGripEdGrip Frets: 736
    I've almost bought a Hardwire Valve Distortion a couple of times to cover that area - all the demos of it sound ace.
    The Jackhammer's a good call, though the "dist" side is very dark and woolly - probably a useful sound for something, but limited. Worth it for the OD side alone though!
    Boss DS1, of course.
    Joyo US Dream, Mooer Solo and that Rowin above are all straight (and affordable!) copies of the Suhr Riot, a popular hard-rocking pedal that is derived from the original Marshall Guv'nor.
    (So is the MI Audio Crunchbox incidentally, another popular Marshall-y distortion pedal - Moore do a clone of that, too, called the Cruncher.)
    Lots of names, but any suggestion on this thread will bring the crunch!
  • xSkarloeyxSkarloey Frets: 2962
    Ayukka yukka yukk.
    They do Bostin pedals as well.
    And Blartin pedals for when you want to play the blues...
    I know I didn't list the pedals I've owned because I have owned so many that I can't remember them all.  Out of the ones that have been mentioned I have already owned:
    MI Audio Crunchbox
    DS-1 / Keeley DS-1 / DS-1X
    Suhr Riot
    DS-2 (not enough gain for me)
    Never had a Guv'nor though.
    I don't really like the Suhr Riot to be honest.  I think it's a bit harsh and scooped sounding.... I've tried it on numerous amps and just can't bind with it.
    There are too many pedals really when you think about it.  It's hard to find something that is right for you.
    Zvex Distortion?
    Catalinbread DLS?
    Amptweaker pedals?
    I must admit "distortion" pedals don't really do it for me. As much as I like the crunch of the Rat or my new Shredmaster, nothing makes me grin like the Big Muff. Could be that what you're after is something like that - a different category of pedal?
    The EQ needs adjusting between OD and distortion on the Jackhammer. The OD is (IMO) the better sound from it though.
    The Valve distortion is my choice for 80's hair-rock leads, with the overdrive for rhythm. Both excellent pedals. The OD is quite lairy, as I said before, it's quite like a Mk1 Guvnor, which, soundswise, at the hairy end, gets towards a JCM800 type of sound.
    EdGrip said:
    Zvex Distortion?
    Catalinbread DLS?
    Amptweaker pedals?
    I had the Amptweaker TightRock but sold it.  It did sound good but there was just something about it that I didn't like.
    I had a ZVex Box of Rock a few years ago and it didn't have enough gain for me.  Mind you, at that point I wasn't into the practice of stacking pedals.
    Never had a Catalinbread DLS.
    Or a different kind of amp. One that's capable of good old valve amp crunch.
    I'd be interested to hear your appraisal of the Boss DS-1X.
    That's one on my shortlist...
  • KebabkidKebabkid Frets: 3344
    edited March 2015
    The Wampler Pinnacle is very good but I'm not sure how much of the quality or character of the pedal, or any other pedal for that matter, will come through given the type of device you have and its small speakers.
    Given the Cube Lite is so small and portable, I'd go into a shop with it and try a few different pedals through the unit to see which one works best.
    Having to listened to Richie Kotzen demoing this on YT, there seems to be a fair amount of gain on tap so how about adding something like a Bad Monkey or Nobels OD or Mooer distortion to that sound just to push it. All of those pedals are relatively cheap new and even cheaper used ;)
  • spacecadetspacecadet Frets: 671
    I've got a Radial Classic going. That will certainly get you where you need to be.
