NERD - New Eleven Rack day.
  • digitalscreamdigitalscream Frets: 28017
    Here's part of that answer I didn't understand:
    Open Audio/Midi Setup. Go to the Audio window, click on the "Avid Eleven Rack" and it will show all the 8 inputs and 6 outputs available. Note the input/output naming there and what number is what (that is not presented inside Logic). And these inputs and outputs are all explained clearly in the Eleven Rack user guide.
    Open Logic, Preferences>Audio and select the Eleven Rack as the input and output interface. Assign the appropriate audio track inputs you want. Output should default to main out.
    When he says Open Audio/Midi Setup...
    does he mean in Logic, 11R or Mac?
    I suspect he means in the OS X control panel, but what have you got to lose by looking in both places? You won't find it on the Eleven Rack, though.
    <space for hire>
