Bandcamp
Spotify, Apple et al
Noise, randomness, ballistic uncertainty.
I had a few pops when I had a true bypass delay pedal last in my chain. I moved it so I had a buffered bypass pedal last and the pop went.
Try replacing V1 in the amp. If it fixes it you can still most likely use that valve in another position - in fact if you don't have a spare valve, just try swapping V1 with any other 12AX7 in the amp.
