The main reason I changed them was not specifically to get brass but to fix the intonation. The intonation was horrible with the stock saddles and I wanted to get some compensated ones. The ones I got were brass. What I would say is that whatever material they are made from, you will probably want to get compensated saddles. The guitar just didn't sound in tune with the original saddles. I don't know if anyone does compensated threaded steel though.
From memory, steel saddles were louder and the guitar was a bit punchier.
I may try a six saddle bridge to be honest - I just love the look of three saddles! Are compensated ones like callaham really that good? I can't imagine how they can accurately compensate so I assume it's just a rough, better than stock estimate?
With compensated saddles I got mixed results. One is better with non-comp, two saddles seemed over-compensated. I have some I think if you want to try 'em out (no cost, just ping a pm).
That's very kind of you, but I'll hold off until I've chosen my design. I may go for six saddles.
This is 3 brass intonatable saddles.
contactemea@fender.com
The intonatable saddles are not available on thier own but you can get the compensated saddles from the older '52 Hot Rod in a kit:
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
May get an earvana, I don't have a nut yet so may just drop it off to you when it's done.
what about Alu saddles? there was a big thing about them a while back - personally I like mixing them up on all my guitars.
The Suhr has bend steel and a couple of sintered steel saddles.![:) :)](/plugins/EmojiExtender/emoji/fb/1.gif)
I think a 6 saddle bridge and a combination of steel and brass is where I'll start. I'll experiment and see what happens.
I bet I end up with all steel though...
I wonder what diamond tipped titanium saddles sound like ?
Nil Satis Nisi Optimum
