My recent 8 string build :)
SerratusSerratus Frets: 121
edited June 2015 in Making & Modding
I finished this a few weeks ago (mainly just as an experiment to see if I could do it!) and I got asked on another forum to do a demo of the drop-tuning -> thought you guys might want a look!
It's a fan-fret 8-string (26.5" to 28"), one piece wenge body with bookmatched myrtlewood front, brazilian mahogany one piece neck with Pau ferro fingerboard, 16” radius, narrow/high fretwire, fixed bridge with (initially) a Duncan designed active pickup, to be replaced later!
On the bottom 3 strings I've got a zero fret and an extra nut a whole tone further back. I designed and built a little device out of stainless steel that pushes each string onto the zero fret, which you can lift out of the way to drop the note down to the extra nut.
So here's a quick video of me using the capo thing to drop the bottom strings! Only recorded on my phone so it's probably all treble!!!lol But hopefully you get the idea :) (used my Kemper with a heavy Engl profile).
http://www.youtube.com/watch?v=hFaiA9ss6tw
http://i1135.photobucket.com/albums/m622/Serratus1/Pic%2035_zpsejujk5ti.jpg
http://i1135.photobucket.com/albums/m622/Serratus1/Pic%2043_zpsln3srbqk.jpg
http://i1135.photobucket.com/albums/m622/Serratus1/Pic%2044_zpsdsy62bwc.jpg
http://i1135.photobucket.com/albums/m622/Serratus1/Pic%2040_zps1qdnugog.jpg
http://i1135.photobucket.com/albums/m622/Serratus1/Pic%2039_zpsaitmuylz.jpg
0reaction image LOL 17reaction image Wow! 0reaction image Wisdom
  • PlukkyPlukky Frets: 282
    Wow!
  • octatonicoctatonic Frets: 34307
    That looks amazing.
    Interesting how you've joined the top with some diagonal grain.
    What was the thinking with that?
  • BigMonkaBigMonka Frets: 1817
    Wow, that's amazing craftsmanship, and the little extra nut device looks very impressive - not that I've got any idea what it's for!!
    Looks like it extends the string length by a semi-tone and a tone.
  • GuyBodenGuyBoden Frets: 806
    Great build, very impressive, just a question, no criticism, it's a great guitar, but what was the idea behind not using the nut to hold the bass strings in position behind the zero fret?
  • monquixotemonquixote Frets: 18304
    That looks brilliant.
    Awesome skills.
  • SerratusSerratus Frets: 121
    Well, effectively the zero fret for the bass strings is the partial fret that's a whole tone lower (halfway along the headstock), and so they have their own nut behind that :) If the other nut went the whole way across the fingerboard then it would get in the way of the bass strings when they're dropped back to the lower note. Did that make any sense???!!lol
    octatonic said:
    That looks amazing.
    I bought the bookmatched top cut at that angle so I just left it as it was - when I knew I was building a fan-fret I decided to use this top because the diagonal grain matched the angled bridge :)
  • stonevibestonevibe Frets: 7339
    Should be in the 'Making a Harp' section.  ;)
    Looks great!
  • Hertz32Hertz32 Frets: 2248
    Thats BRILLIANT :D How do you have it tuned? I have my 8 in 9 string standard skipping the F# so; C# B E A D G b e
    What are you replacing the Duncan active with?  I quite liked the Duncan designed active I played, I have a set of EMG 808's you maight be interested in?
    'Awibble'
    It's just standard 8-string at the moment F# B E A D G b e, then the bottom three strings can be dropped to E A D :)
    I'm actually not sure if I'm gonna replace the pickup now - my plan was to only use it as a temporary thing to test it all out, but it actually sounds pretty good. They're based on the Blackout apparently. However, I did make sure the cavity under the bridge plate is big enough to take a Bareknuckle 9-string pickup! Because the pickup is at an angle across the strings, a 9-string pickup would cover the whole width of the strings better, and the BKP passive 9 is about the same width as a standard soapbar 8, so it would fit ok. I would probably make a cover for it out of wenge if I did that. So we'll see! :)
  • TTonyTTony Frets: 28419
    Our humble "wow" really doesn't do that justice.
    That's stunning - design, materials, craftsmanship.  Stunning.
  • lloydlloyd Frets: 5774
    That's some piece of work, I'd have absolutely no use for it but it's amazing craftsmanship. Hats off sir.
    Manchester based original indie band Random White:
    https://www.facebook.com/RandomWhite
    https://twitter.com/randomwhite1
  • randomhandclapsrandomhandclaps Frets: 20521
    That sir is awesome.
    LOL, to be honest I don't have much use for it either!! But it was a fun project to build :)
  • Andyjr1515Andyjr1515 Frets: 3129
    Top drawer stuff :). There's both superb craftsmanship and also technical innovation mixed in together. Fantastic =D>
  • stickyfiddlestickyfiddle Frets: 28678
    Crikey! Not sure how I missed this but it looks incredible.
