I take said guitar, stretch strings properly, strum resultant open chord, and say, "really?"
They're like, "oh.."
@Maynehead, The flanges(?) on the posts of the tail piece and bridge have never been completely flush, as the top is 'carved' (actually 'carved'? At this price?) and the flanges aren't angled. However, the bridge has always been marginally tilted backwards, with the post on the right (as looked at when guiter held with the head up), has always been a bit more 'skew-wiff' than the left post. I have always been able to see the vertical lines (brushings?) on all posts to a small degree, but none of this has had any effect before.
I was planning on the tech straightening the posts and knocking them in a little further (as part of the jobs I was going to have done) so that at least the inner part of the flanges are flush to the body. Really just because it tidies that bit of the guitar up. I have seen LP's etc. on the interwebnet with posts a bit like mine, so I wasn't worried.
I don't think it's to do with string streching, because the problems started before I put the new strings on.
Also done a quick online search for suitable pics which show other guitars with 'not-completely flush flanges'.
Haven't found any yet.
Have done more string stretching. Seems to have helped. Although the trebles still to want to not stay in tune.
I still don't understand why suddenly, this guitar, out of all the ones I've had and strung the same way, should decide to have this trouble now. Actually to have this trouble even before I re-strung it.
Is 'she' buggering about 'cos I ain't decided what her name is yet? Or 'cos she's told me her name but I ain't understood? Is it her 'time of the month'? :-S
Wouldn't surprise me. Huh, Ruddy women!
:P
If 'she' carries on like this, then maybe next year 'she' can have her plastic dots swapped for mother of pearl ones?
So it seems to be not caused by :
Old, old strings.
Not properly stretched strings.
The heat/weather. As the weather here is different now to how it was then.
The strings aren't duff as this has happened with sets from different batches.
Should I just take the view that guitars are really 'women' and are subject to the guitar equivalent of 'being on the blob'?
You can just get a duff neck that won't hold its relief and can be overly environmentally sensitive which can be caused by anything from the wood through to truss rod fit.
Can also be caused by a poor fitting case if the neck is compressed.
Depending on the value of the guitar it isn't always worth the cost of trying to get fixed if its neck related.
Duff or fake strings. I suppose it's possible, but that wouldn't explain why it stayed in tune (bar the usual tweaking) for most of a year with the old set and then, with the same set, started to go out of tune, nor why it stayed in tune for about a week with the new set.
Environmentally sensitive. Again, I suppose it's possible, but that wouldn't explain why it started with these problems before we got the 'heatwave', carried on during the 'heatwave', carried on after the 'heatwave' then stopped for a short time then went back to giving trouble the other day while we had the same type of weather as we did during the week it wasn't giving trouble.
Poor fitting case. Yet again, I suppose it's possible, but I've had the Guitar and case since 2013 and it hasn't given any trouble for most of that time. I wouldn't know how to test if the case is a poor fit. I can't close it and open it reeaallyy quick to see how the guitar is inside with the lid closed.
Thanks for the replies though. A couple of suggestions which even ICBM doesn't seem to have considered.
