Yes, youve likely got the wiring confuzzled on the log pot
*Unless*:
1 - you're left-handed, in which case you need Reverse Log for it to work properly. Linear is marginally less bad than Log wired backwards, but not much.
2 - you actively want it to do that, eg for 'tone control wah', so the range is over the first quarter turn.
3 - you want it to have a small range at the dull end for a jazz tone, in which case something like 100k Lin will work.
If none of those things apply and it still cuts off abruptly, the pot is poor quality. Cheap Log pots are often made from two sections of linear track instead of a proper Log one.
Eqd Speaker Cranker clone
http://www.thefretboard.co.uk/discussion/61134/sarge/p1
