Traditional or alternative?
Prepped or un-prepped?
Single or Multipiece?
Budget?
David Dyke is always worth a call for traditional or more exotic stuff, but bare in mind a lot of luthier supply houses will assume you have the skills to fully prep the wood and don't assume 2-piece means the same as centre joined 2-piece. essentally, make sure you ask for what you want and David is great. Just order a 2-piece alder bdy blank without saying anything else and you will get some great wood that may need a bit more work or may not be what you had in mind... just let him know what you have in mind
http://www.luthierssupplies.co.uk/
At the other end of the spectrum you can pop to allparts and order an ash or alder body blank that is so fully prepped you can pop a template on and build with it with no more work. but you end up paying a lot more for the convienience. The wood is usually comparable to decent fender stuff
http://www.allparts.uk.com/collections/body-blanks/products/body-blank
As an alternative I recently ordered some wood from sherwin timber on ebay. Its none traditional stuff like Idigbo and meranti, but it was a very good price and nicely prepped so it just needed glueing up the multipiece bodies. I have not tried the ash or sapelle and wouldn't without going to check it out, both can be very heavy
worth lookign in the body blank section - but have a looka round the rest of the shop too... i got an idigbo mantlepiece for very little money, and it makes a very large body blank once cut in half
http://www.ebay.co.uk/itm/Guitar-Body-Blanks-Ash-Tulipwood-Sapele-Meranti-2-3-PIECE-UNGLUED-/181773608773
there are also a couple of other guys where the websites are never up to date but if you have specific requirements its worth giving them a call to see what they have
http://www.primetimber.co.uk/products/instrument_woods/
Instagram
Instagram
Football is rubbish.
(formerly miserneil)
