Nil Satis Nisi Optimum
Feedback
Instagram
The thicker option I am considering would be more like acoustic back thickness.
Instagram
Instagram
I have used some from a different supplier, I think they were double standard veneer thickness, about 1.2mm if i remember right.
TBh its not too much of an issue either way, I would just rather I had something over the plugs to help stop block shapes reappearing through the finish. If I go standard veneer I will be able to add it without taking any wood of the body - it will just be slightly thicker. If I go with thicker veneer, or a thin top then i will need to remove more original wood but I will garantee neater edges and the change to dimensions
It will work out nicely either way, its just a different set of processes. I have done both before
Obviously there would also be the option of adding a fancy top, but I don't think we will go that way
Instagram
Instagram
Instagram
Instagram
Instagram
