My band, Red For Dissent
Many guitars have a re-sale value. Some you'll never want to sell.
Stockist of: Earvana & Graphtech nuts, Faber Tonepros & Gotoh hardware, Fatcat bridges. Highwood Saddles.
Expert guitar repairs and upgrades - fretwork our speciality! www.felineguitars.com. Facebook too!
I'm a bit confused by the 1.5mm grub screw in the tremolo mounting posts. In terms of tightening, is there a point they should stop moving? They get to the point the allen key becomes unremovable, so I'm a bit confused. All in, I've learned quite a lot from this experience, although I'm yet to get the intonation on the low E right, which oscillates horrible past the 12th fret.
Yes. Very important. You should see on the side of the trem a line scored onto it. This line should be parallel to (and level with) the guitar body!!! It often looks tilted but isn't.
You just loosen the inner one, then move the height of the post with the bigger outer one, then lock it with the inner one again.
And @ICBM I'll try adjusting the pickup heights. Ta!
