Also possible there could be something loose in the wiring which is vibration-sensitive when you strum hard.
And check for microscopic 'whiskers' of metal (usually wire wool) stuck to the top of the pickup - if it contacts the string it will cause a crackle - this is more common on bridge pickups because the gap between the pickup and the string is smaller.
