2008 Matchless DC30 2x12 combo. Awesome amp but unfortunately has to go. This is the older style 4 input (2 per channel) version. I prefer this when used with an A/B switch as you can isolate certain effects on each channel. Sounds glorious, as you would expect. Don't be fooled by the 30 watt rating, it's seriously loud. Comes with a padded cover made by Hot Covers. These are now a colossal £4000. Will accept £1800. I am based in Gloucester.
Pics below.
Cheers fella a little different to the 'other' forum.
this is one of the best amps ever
