Your "top tip" please.......
thebreezethebreeze Frets: 2819
Tomorrow evening I'm playing a gig for the first time in 30 years.  Maybe 200 people, village hall.  Gulp.
I thought it might be fun (or even useful :)) to get a "top tip" from each of you?
«134
  • TheMarlinTheMarlin Frets: 8120
    Keep a careful eye on all your gear, and try to enjoy it.
  • RolandRoland Frets: 8846
    Warm up. Your body will naturally go tense in front of an audience, making it harder to play fluidly. Find a few minutes to run through some finger exercises.
  • Warm up, and drink plenty of water.
  • bigjonbigjon Frets: 681
    Place your feet wider apart than normal when you play - makes you look more confident.
  • djspecialistdjspecialist Frets: 917
    edited December 2015
    I did something similar a couple of weeks ago. (First gig in about 15 years, to an audience of about 100 people).
    It went fine, we had a blast and the first thing we talked about when we came off stage was "when can we do it again?". I'm sure yours will be the same!
    Don't sweat over mistakes (which you'll definitely make!) - nobody will notice. Enjoy yourself, and show that you're doing so - people will notice that.
    Trading feedback | FS: Nothing just now
    JM build | Pedalboard plans
  • TeetonetalTeetonetal Frets: 7829
    Don't spend all night staring at your fretboard.
  • GassageGassage Frets: 31132
     Wear spandex.
    5reaction image LOL 1reaction image Wow! 3reaction image Wisdom
  • Take a baton to beat off the female hoarde
  • ICBMICBM Frets: 73031
    Raise your amp up off the floor if you're the guitar player - a chair is perfectly adequate if you don't have anything more professional. That lets you hear your own amp properly and reduces the tendency to set it too loud and too trebly, and it will project better into the room so you won't need it as loud anyway.
    Keep it tight down (including removing the wheels, if it has them) if you're the bass player. That couples the cabinet to the floor and both fills the space better and improves the sound.
    Doing that with both amps produces a more natural mix with the bottom octave of the guitar rolled off and the fundamentals of the bass reinforced without having to do anything with EQ either on the amp or the PA.
  • lloydlloyd Frets: 5774
    Listen to what the other people are doing and adjust accordingly
    Manchester based original indie band Random White:
    https://www.facebook.com/RandomWhite
    https://twitter.com/randomwhite1
  • Mine is always the same - know where the toilets are. Other than that think through what you will need and take it all. Some people like to get into gig mode with a change of shirt or what have you - look in the mirror and go I Rock rather than look in the mirror and go I Look Like a Junior Accountant With a Borrowed Guitar. And it's not a recital so enthusiasm is more important than accuracy (well, up to a point).
    A hat and/or facial hair is a big help too. \m/
  • frankusfrankus Frets: 4719
    Smile at the audience and breathe slowly :)
  • HAL9000HAL9000 Frets: 9817
    Keep one foot tapping. Simple but def helps with timing. Don't overplay. Enjoy.
  • At the start at the gig, look at the audience and allow them to look at you (psychologically, it makes a huge difference) - you're there to be seen as well as heard.
    99 times out of 100,  if you make a mistake the audience will only notice if you tell them by how you react. Let it go, get on with it and enjoy youself. Even your own band won't notice half the time - unless you're the drummer, that is.  ;)
  • Allow the instrument to acclimatise to the venue for an hour before tuning. Tune up just before you play, use a meter not your ears and mute the signal to the amp while tuning.
  • RockerRocker Frets: 5022
    Good luck my friend.  My tip is to have spare [cables] to hand in case one decides to sulk.
    Nil Satis Nisi Optimum
  • Write a list of your gear - everything you need and spares, including stage clothes, mobile 'phone, water bottle, etc. Check it into the venue and, more importantly when you're walking on clouds after the gig, check you've packed everything back into your car, especially leads (and guitar and amp).
  • BigMonkaBigMonka Frets: 1793
    But make sure you go to the toilet before going on stage!
    +1 Keep looking up and look at different places around the room to engage with the audience, not just the front row.
  • vizviz Frets: 10771
    Wear a gorilla suit
    5reaction image LOL 0reaction image Wow! 2reaction image Wisdom
