Secondly, the correct way of checking nut height is to fret each string at the third fret - it should be possible to lightly tap each string on to the first fret (using your other hand). There should be a gap between the bottom of the string and top of the first fret - but it should be very slight (a couple of thousands of an inch or so). This method takes saddle height out of the equation when assessing the nut.
Finally, the amount of belly in the top of an acoustic varies a lot with humidity. In dry conditions, they flatten out - which will drop the bridge lower. In more humid conditions, they bow more, which lifts the bridge.
You need to consider all of these issues before cutting the saddle down. Often the reason an acoustic's action is too high is due to a combination of these factors - and cutting a saddle too low can compromise tone due to the lack of break-angle.
