My YouTube Channel
PRS's recommended action height is significantly higher than they can usually be adjusted to - and therefore should cope with some wear.
My guess is he's looking for work....
My YouTube Channel
Instagram
My YouTube Channel
Paul Smith uses wire that he thinks 'sounds' good, as well as wearing in an acceptable way.
IF - and it is a 'if' your frets need dressing, that is not a reason to go for a refret. PRS frets have reasonable height, so will stand dressing with little or no change to the feel of the guitar.
Unless you are getting unacceptable levels of buzz, I doubt your guitar needs any attention at this stage.
Instagram
Instagram
My YouTube Channel
