Body | GSPBasses Body | 160 |
Neck | Mighty Mite Stratocaster Neck | 89.75 |
Finish | Wudtone Colourless | 17.99 |
Bridge | Wilkinson Roller Bridge | 24.5 |
Tremolo | Jazzmaster Trem | 89.99 |
Pickups | Mojo 58-61 Set | 80 |
Wiring Harness | Mojo Wiring Harness | 80 |
Pickguard | Allparts Tort | 22.4 |
Tuning Machines | Wilkinson EZ Lok | 34.99 |
599.62 |
Of course you could go the other way and send it out for paint. That will make wudtone look cheap
Instagram
They will get you buy and work fine, although the quality step up with grovers is quite noticeable... Just because they are made in the same factory does not mean they are made to the same price point.
Instagram
[/quote]
That is a good idea. Is there anything I should look out for in particular?
Get them when you order the neck.
:-bd
^^^^ wise words, these ^^^^
I thought we were simply talking about cost? Hopefully we all accept that cost cutting risks a reduction in quality and we don't need to debate that too much
So a natural finish can be had with Wudtone for £18 which will give you enough to do one guitar. I have used the Wudtone natural finishes and quite like the feel and ease of application of the finish - but the question here is whether a natural finish can be achieved cheaper, or at least I thought that was what was expected by the OP???
Well a bottle of Danish oil from Wilko's costs under £4 for enough to do 3 or 4 complete guitars (or enougth to do one guitar 3 or 4 times). Thats the simplest natural finish I can think of. Its one I know people have done in the past and been happy with, although it is quite a raw feeling finish so not suitable for all. If @olafgarten was happy with a simple oil finish he can still have a natural Jazzmaster for £4 of finishing costs.
I said Oil & wax,not just oil, because thats the finish I prefer. Its going to add to the cost but can still be done for £10-15 worth of finishing materials
Now for a really good high quality oil and wax finish I recommend Briwax and Rustins Danish oil (or tru-oil), but it also needs a few other materials to get it really nice. Its as much about the process as the materials you use. So the price for one guitar will be comparable with the wudtone cost, but you are left with enough to do multiple guitars, or the same guitar multiple times. I mention this because its not uncommon for DIY builders to need a couple of attempts to get it right. Oil and wax is pretty foolproof in that regard.
I have to make these decision myself sometimes. I have recently lacquered my LP build myself because I needed it done cheap. I spent £50 on paint rather than £200+ on posting it to a sprayer and having it done really well. The money all went on hardware and pickups instead. I had to accept I did not have the budget for that so the finish I would be able to achieve would not be as high quality as a pro-spray job.
You either have to decide what quality you want, or what quality you can afford that you will happily live with after - I thought that what this thread was about?
Instagram
