@BenSirAmos
It's ok, it's not really like you are putting me off, it's good advice your giving me, I am, as you mentioned, extremely cautious with stuff like this, especially when I could make an expensive mistake. That and I am very choosy about the way my guitars play.
I lose count of how many random days the guitar just feels totally different and more hard work to play. The recent spell of weather probably explained a lot and woke me up to the fact that wood moves a bit, and even when temp/humidity changes are not extreme I suppose it does too.
The VSOP felt a little better to play when I lessened the relief. I also adjusted the Wolfgang just under 1/8 turn clockwise to lessen the relief, but it didn't seem to make much difference and felt as though the strings had more tension even though it was still in tune to Concert Pitch. The VSOP felt ok so I was relaxed but the Wolf not changing much sort of tensed me up a bit.
It may sound silly but I worry about differences like the following: The Wolfgang has a wheel at the Guitar Body end of the neck so clockwise is away from me(right handed guitar in playing position) whereas the VSOP has a Hex Socket at the Headstock end and Clockwise would be towards me. It still makes me think I have turned the Wolfgang wheel the wrong way.
After adjusting I usually let the guitar rest a couple of days and have it in the case stood near upright, is this fine or should it be layed flat?
Sorry to nag you with all this.
@ICBM
Thanks too for your explanation prioritising what might need adjusting in temp changes regarding the truss rod and the bridge height.
Moving or to your VSOP (which I always thought was a brandy...) - looking at the hex-key from the headstock side, with the neck behind - again turn clockwise to tighten/counter-clockwise to loosen.
TBH I don't think it matters whether the guitar is in its case or not after adjustment. Just make sure it is tuned to pitch.
@richardhomer
Thanks Rich, I got it, just making sure.
A brandy sounds a good idea actually
@BenSirAmos
Thanks ,Ben. I'll start doing more research and learning about this stuff and get a set of gauges.
If the OP sticks to the basic principle that clockwise tightens and vice versa and uses the strings as a straight-edge (with the guitar in the playing position) to access relief, no disasters will happen.
