FS: Strat style body + hardware £100
Pics: https://goo.gl/photos/Wb8thP2YpdMqu1Yx7
This is a strat style body I bought from someone on the forum probably about 10 years ago. It's stamped 'Chandler Industries' in the neck pocket but I'm not sure where it was actually made. I'm also pretty sure it's made of basswood.
Included in the sale is all the hardware you see in the pics. Just add a neck to make it go!
The pickup is a Swineshead Warthog, and it sounds like this:
It's currently wired with a push/pull pot to do a coil split, but the split sounds naff so I'm pretty sure I wired it up badly/wrong.
There's also a cavity cover which I completely bodged out of a piece of plastic so the fit isn't quite perfect.
The bridge is a perfectly solid Wilkinson one.
I'm not really sure what it's worth, so I'm gonna initially say I'll let the whole lot go for £150 £100 delivered, but if I'm way off the mark I'm sure someone will let me know.
Any questions just ask!
I'm also after a Boss AW3, so will consider trades plus cash.
Soundcloud: https://soundcloud.com/iainflockton
I did think it was you I got it from but didn't want to tag you just in case it wasn't!
It is a great body, regardless of the blemishes.:)
