Anyone know of reasonably priced nut files
paulnb57paulnb57 Frets: 3219
edited February 2016 in Making & Modding
After nut files, not welding tip cleaners, just good reasonably priced files, anyone know of anything?.....
    I managed to lose all of mine, but got one of these off ebay and it works a treat. Took about a week to arrive iirc.
  • paulnb57paulnb57 Frets: 3219
    Interesting Jooky.....might be worth a punt.....
  • SargeSarge Frets: 2436
    Rohko&frost have thrm @£14 a pop on ebay, luthitec brand, no idea how good tho
  • strtdvstrtdv Frets: 2587
    I'd avoid anything that cuts a V shaped channel. You want a U shaped channel for a nut or you'll risk string binding.
  • LooseMooseLooseMoose Frets: 941
    Crimson Guitars. Tenner a file, done!
    Its one of those tools that is outrageously expensive, they are a ridculous expense....
  • ChalkyChalky Frets: 6813
    There simply aren't any good cheap nut files.
  • sweepysweepy Frets: 4265
    Absolutely 100% correct
    I know, but there should be IMHO, most other files are reasonably priced, I think it's just profiteering for "specialist" files, there's really nothing technically special about them, I can get a set of needle files for about a tenner, about a pound each........
  • Marktigere1Marktigere1 Frets: 101
    I use these Electric Nut Files
    Been buying from him for nearly 2 years.  Great delivery and good products.  He is based in Portugal.
    I am also a Crimson Guitars customer, again great service but I do like Hosco tools.
    Cheers
    Mark
    I bought a Hosco set, well over 10 years ago, they have more than paid for themselves although the 0.010 could do with a reinforcing spine . In short, never skimp on tools, it really is a false economy
  • meltedbuzzboxmeltedbuzzbox Frets: 10343
    dont the Stew mac files cut a V?
    Then start a business making them! But you'll soon see it doesn't make financial sense. Nut files have no use in any other application. Their precision widths make no sense in any other application. None.
    So why would anyone bother making them just to lose money?
    Back in the early 80's I used to use glass saw a for high E and the B, then ground down and beaten hacksaw blades for the rest ! Oh happy days ;)
  • WezVWezV Frets: 17462
    The cutting edge is a U shape but the files then get thicker to ensure they don't snap.   As long as your slots are not too deep they will come out as a U shape, even a deep slot will be a slightly splayed U shape rather than V.  this is much better than an actual V shape as its round on the bottom
    ah yes
    "(String slots may need enlarging depending on string gauge)"
    Unfortunately there is no getting away from the need for nut slotting files when fitting the nut.  You can get away with just sanding the bottom on a flat nut, but its very hard to get that as accurate as a properly cut nut
    I will feed back on that nut as I am going to order one.
    I think/have finger crossed that it will take an 11 gauge
  • FelineGuitarsFelineGuitars Frets: 11966
    edited March 2016 tFB Trader
    I have often sold a used set of Stewmac ones now and then as we tend to replace our sets every few years
    Still plenty of life left in them but we like to have nice sharp files as they get used many times a day
    None up for grabs at the moment, but seem to recall that a few FB members have snapped up sets in the past.
