Power adapter with daisy chain connectors
midlifecrisismidlifecrisis Frets: 2343
i have the above but all the connectors are right angle ones which isn't a problem for most pedals but if i want to use it on my zoom g3, the socket is recessed making it very difficult to connect. is there an adapter available to fit on either the connector plugs  or into the zoom or do i have to get a straight plug and cut off one and solder the straight one on?
  • simonksimonk Frets: 1467
    Can you trim some of the plastic off to leave more of the barrel showing? Alternatively you can get 9v extension cables on eBay with a straight jack... you'll just have to bunch the excess cable up under the board.
    will try trimming, there isnt a lot of barrel showing but it might just be enough, or yes, il look for extension leads.   thank you
