An amp for guitar and bass?
RockerRocker Frets: 4989
I have a bass amp and several guitar amps. When playing music with friends, there is enough equipment to lug to and from the car that I wondered if there is one amp that will do both jobs. Reasonable sound for both and not heavy. Not gigging loud. Not heavy, bad back. Thanks.
Nil Satis Nisi Optimum
  • axisusaxisus Frets: 28341
    Yes, any amp at all. The only downside is that you will sound like sh*te when you plug the wrong instrument in.
  • From the thread title I was going to suggest the Orange Thunderverb 200. But I think it might be a tiny bit too big and a bit too loud.
    Just a bit though.  :o
    Get an old peavey
  • martmart Frets: 5205
    Use a bass amp, and plug in an amp simulator pedal to get your guitar sounds.
  • JezWyndJezWynd Frets: 6095
    Probably not the solution for your situation but I get a very nice bass sound using a Laney Cub valve amp, feeding the output to a 2x10 cabinet. This is much better solution for my needs than putting my guitar though the bass amp, which sounds very poor.
  • fretmeisterfretmeister Frets: 24495
    The litle Roland Bass Cube amp the old 20XL is great for guitar - it has an excellent Fender Bassman model in it, and that started as a bass amp that guitarists love.
    Or get a Helix and FRFR cab.
    Fender Bassman, the obvious choice.
  • 2061x + cab of your choice - possibly with one pedal per instrument type (guitar, bass) to tailor your sound?
  • steamabacussteamabacus Frets: 1267
    I'd suggest something like an old Polytone Minibrute combo if you can find one - compact, 100w, 1x12.  A friend had one as a bass amp but it had a perfectly acceptable guitar tone (in a 'jazz' kind of way, add an overdrive/preamp style pedal for janglier or more driven tones).
    Some of the old Keyboard combos like a carlsboro or similar will have the inputs and a half decent response range to cover Bass, Keys, acoustic guitar, even a mic if pushed. A guitar amp tends to have quite a narrow frequency response ofton with a mid hump built in. By using a cheap pod type thing into such a combo an electric guitar like sound can be easily achived, a behringer would be an option or a graphic with a non smily face at the end of your effects input chain.
  • RockerRocker Frets: 4989
    Weight and a reduction in the number of 'boxes' that need to be transported is the reason for my search.  My Markbass is a fine bass amp but poor for a guitar.  And my Stinger combo is the opposite.  The Markbass is light, the Stinger is damn heavy for a small box.  @mart, what is an amp simulator pedal?  I never heard of one so please school me.  @fretmeister, the Roland Bass Cube seems like a good solution, I will check it out a.s.a.p.
  • ICBMICBM Frets: 72513
    Strangely, one of those 1980s solid-state 15W amps which was sold under various brand names (eg Solex) works quite well. They're all the same in having an 8" speaker, three 'gain' controls (I think usually labelled volume, distortion and master) and three-band EQ. Just set the gain and EQ differently for each - it won't be perfect, but surprisingly passable. The bass player in one of my old bands actually used one as a personal monitor on stage, for small acoustic-type gigs - with the main signal DI'd into the PA. As long as you don't overdrive the speaker it doesn't seem to do them any harm.
    On that basis the Fender/Squier 15 might be even better since it has a closed cabinet with forward-facing ports, and the usual problem for guitar is stopping them sounding too boomy. I've never tried one for bass but possibly I should!
    All of these are very small and light, and cheap - under £50 in full serviced order from any shop, maybe less form Ebay.
    Rocker said:
    ....  @mart, what is an amp simulator pedal?  I never heard of one so please school me.  ...
    Something that reproduces the tone-shaping of a preamp and speaker cab, without amplifying the signal very much, like this:
    http://www.tech21nyc.com/products/sansamp/images/blonde_sm.jpg
    https://www.gak.co.uk/en/tech-21-sansamp-blonde/55529?gclid=CKv6wpDvsNMCFRe3GwodLuoKRw
    or
    https://images-na.ssl-images-amazon.com/images/I/613DrKx939L._SX355_.jpg
    https://www.amazon.co.uk/JOYO-JF-13-Vintage-Amplifier-Effect-x/dp/B006QUGBVK
    or or there are many others, emulating various different classic amps.
