A looper you don't need to double-tap
ijontyijonty Frets: 32
Hey all
I have the tiny Ditto Looper which is great for the price. However, I'm finding that it sometimes needs more foot-taps than I can efficiently do during a song. Essentially because there is only one footswitch to do everything.
Perhaps this is obvious, but what I mean is, I can record a loop as normal by tapping to start, tapping to stop. But then if I want to turn off the loop later in the song so I can play a chorus, but then put it back on again, I need to double-tap to stop, which throws my rhythm right off.
Presumably I just need a pedal with separate start and stop switches (or better foot/brain co-ordination)? What model of looper would be best to upgrade to?
Cheers,
Jon
________________________________________________
Telecaster American Deluxe, Cornell Romany amp, without the talent to use them properly
  • ICBMICBM Frets: 72445
    Akai Headrush E2
  • GavRichListGavRichList Frets: 7171
    The infinity is amazing - and there are a couple for sale on here at the minute
  • TeetonetalTeetonetal Frets: 7807
    indeed
  • ijontyijonty Frets: 32
    Thanks all!
  • VoxmanVoxman Frets: 4725
    edited April 2017
    ICBM said:
    Akai Headrush E2
    Thats what KT Tunstall used.  Easy to use, brilliant for live impromptu stuff but no facility to save loops.  I had one, but sold it and got a Boss RC3 - 99 memory slots, 3 hrs recording, plus 10 drum beats, compact, LED display, & built like a tank.  Brilliant looper but a bit awkward live with just the single pedal - BUT I had 2 x latching Bespeco VM22's pedals that I plugged in to make it super easy to use (just £5.99 each from DV247 - don't get screwed by silly Boss prices!).
  • JalapenoJalapeno Frets: 6393
    Digitech JamMan Solo or JamMan stereo - both take SD cards to save or upload loops.
    Feedback
    Voxman said:
    ICBM said:
    Akai Headrush E2
    Yes, KT using hers is a perfect illustration. In the end I sold mine and got a Boss RC-1... I know it's much more limited but the Akai was too big, won't run on batteries, and the Boss has that useful LED display. I do miss the ability to undo the overdubs though.
  • steamabacussteamabacus Frets: 1266
    The Solo (at least the XT version I have) will require an additional FS3 footswitch* for single-press stop functionallity.
    The obvious answer to the original question would seem to be the two button version of the TC Electronic Ditto ('Dual Ditto'?) - assuming the second footswitch is for stop (as would seem practical)?
    * Or make your own like I did - it's a fairly simple circuit. Or I believe Bright Onion do a version that is probably cheaper than the Digitech one.
    Good point. All these suggestions sound great, but probably way too clever for me. I thought the Ditto x2 had a second switch, but for FX. I've looked at the manual online though and looks like you can use it to stop too.
  • ellangusellangus Frets: 250
    edited April 2017
    Ditto X2
    2 x switches with added stuff.
    one switch works exactly like the ditto, the second switch stops it (also has a half speed function and reverse function at the flick of a switch).
    I may be selling my X2 as I would prefer the original Ditto due to it's simplicity and the fact I only use it for practice.
    Along with many others, I got Scammed by J Collingridge 'Award Winning' Photographer. Full details about his behaviour on this and other forums can be found on this thread. If you have been Scammed by J Collingridge 'Award Winning' Photographer, let us know and even if you haven't, putting a similar message in your own signature will help us warn others.
    ellangus said:
    Ditto X2
    Want to trade? Plus whatever's fair to make up the difference?
  • hywelghywelg Frets: 4303
    Digitech Jam Man Stereo. Mine is surplus to requirements now I have  a Trio+
    http://www.thefretboard.co.uk/discussion/83074/fs-digitech-jamman-stereo#latest
