Hello gents. I recently purchased a Tascam Portastudio 424 MK3 on ebay without the adapter thinking it would be easy to find another one. It isn't. The only ones I've found cost 70 quid from the states plus import fees. I've considered taking the job on myself but as I'm reluctant to blow the unit, my house or even myself to smithereens, I was wondering if anyone here would be willing to take on the job in return for a fee?
I have the transformer, I assume it's the correct one:
http://uk.farnell.com/pro-power/ctfcs50-12/transformer-50va-2-x-12v/dp/1780891?CMP=AFC-CJ-UK-3640931&source=CJI also have a 6 din custom cable that was sent with the unit, plus a metal case that I have lying around somewhere.
If you want to take on the job, let me know, and we can discuss further details.
Cheers,
Frank
Unfortunately there are no 3rd party adapters that are suitable, and i'm reluctant to spend over a hundred quid to get one imported from the U.S
Just for info, I found he following info:
https://www.gearslutz.com/board/low-end-theory/816449-modding-tascam-424-mkiii-portastudio.html
...summary, according to one of the later posts it needs a centre-tapped transformer, and all the rectification/smoothing occurs in the recorder itself. No guarantee this is correct of course...
So it looks like the centre tap goes to pins 2 and 3, and the two AC connections to 1 and 6, and 4 and 5, respectively. (It doesn't matter which way round, as it's AC.) You could probably get away with connecting to just 1, 3 and 5 - that would also remove the possible symmetry issue.
If this still sounds to difficult to do yourself, drop me a PM if you can't find anyone local to do it.
