Restrung my MIM strat with 10s this week (10-46), when it has only had 9s previously.
plays very nice with the 10s (as it did with the 9s)
however I am sure the term/tailpiece was never as raised as it seems to be now. Does this level of "raise" look ok ?
also any idea on what I have done with the displaced screw on the bottom pic. I am guessing i just need to loosen the strings off and screw something back down, but am just wary in case all manner of little bits of silver metal will spring off into all corners
advice gratefully received
https://www.dropbox.com/s/52eo6fj3tg0cquk/File%2022-04-2017%2C%2012%2013%2001.jpeg?raw=1
Neck relief is a personal preference like string height. If you do fell you need to adjust the truss rod, do it in very small increments.
surprising how much I had to screw the big springs in to get it down
sorted the grub screws on the E string
going out to do Go Ape now (!?) so will look at it this evening and see if the neck needs a twist too
thanks all
Ref the trem - there is no definitive set-up that suits all - some want it floating (some more than others) - some what it flat or nearly flat - some want 5 springs and flat to give more 'vibration/resonance'
Before you do anything, remove the back plate and find a piece of wood that fits exactly between the rear of the trem block and the body. It should have no gap - it needs to be an exact fit.
Replace the strings and tune to pitch. The extra tension will hold the piece of wood firmly in place. Gradually tighten the trem claw screws until the block can be removed and the trem will be floating in exactly the same place as before you started.
strat now set up nicely. Main spring tension sorted out, did intonation, and string heights. Playing beautifully now.
decided to do similar to my LP. Tuneamatic was fun, I thought it was on the wrong way round as it is difficult getting to the intonation screws from the bridge pickup side.
so loosened strings off, flipped it round and then did the intonation easier from the tailpiece side although I think that is wrong now I look at it, so I will turn it back tonight and take the opportunity to restring
