SOLD: Bugera 6260 Head (Blowing fuses - needs new tubes) - £50 ONO.
Jack_Jack_ Frets: 3175
edited April 2017 in Amps £
For sale is a Bugera 6260 Head.
  • Power: 120W (tube)
  • Tubes: five 12AX7 (preamp); four 6L6, convertible to EL34 (power amp)
  • Two channels
  • Two inputs: high gain; low gain
  • Controls: 3-band EQ, presence, crunch button, gain, volume, reverb
  • Built-in reverb
  • FX loop
  • Impedance: 4, 8, 16 ohm
I took this on with the intention to fix it myself, but I don't have a cab at the moment and this is now getting in the way. It's blowing fuses - a quick google search suggests this is quite a common issue with Bugera amps, and it's just a sign it needs tube(s) replacing.
I did give it a good clean, including the innards, so it's ready to work on.
With a bit of knowhow and a tube (or a set) you can have a fully functioning 6260 for £50 ONO.
Collection from the Bournemouth area please, or I can meet you within a 20 mile radius. I would consider shipping it if someone else wants to arrange a courier (it's heavy).
Please let me know if you need any more info or want some better pictures. Thank you.
