Does anybody have any tips as to how to get a 'good' sound out of the drive channel of a HRD? Firstly, I appreciate that 'good' is a subjective term!
I don't get the opportunity to use the amp over 4.5 on the drive channel or 3.5 on the clean channel. I did try putting a Boss EQ in the effects loop and driving the amp harder, and whilst it sounded a bit better, I still wasn't entirely happy with the sound. I play in two covers bands, with a mix of material, eg GnR, Red Hot Chilli Peppers, Foo Fighters, Amy Winehouse.
I'm currently only using the clean channel, with overdrive and boost pedals. However, I'm keen to see if I can use the drive channel.
I have discovered something frustrating though - the MkIII doesn't sound as good as the MkII. I thought I was imagining it with the first one, but I've played several of them now and felt the same every time. Sure, they've addressed the usual moan about the volume control tapers - although like the Drive channel, I never really understood why that was such a big problem - but the amp now just sounds flatter and less lively, unless you turn it up further than the old one! One step forward and two steps back in my opinion.
... and that black control panel is just horrible.
I think the problem is that many people expect it to be a sort of 'Marshall in a box' channel, and when it doesn't do that they write it off as unusable.
(Admittedly on a tweed special edition one with the Jensen speaker.)
If you want it to be more guns n roses, you'll want a visual sound son of Hyde or a similar pedal.
soundcloud.com/thecolourbox-1
Don't do that - or at least not if you mean actually running it fully in the FX loop, between the Preamp Out and the Power Amp In. Using an overdrive/distortion in the loop can cause the amp to feed back on itself internally and blow the send/return chip.
If you mean simply connecting the pedal to the Power Amp In - with the guitar going directly to the pedal, not using the amp's preamp at all - that's fine.
Unless you know for sure that it's safe with your particular amp, the simple rule is to never run any kind of distortion (pedal or external preamp, including something like a Pod) in the FX loop, on any amp.
