Aiken talks about coupling caps foil being linked to the valve plate and to the cathode for bypass caps
In this instance as part of the PI, this cap is connected cathode of the PI valve to the plate for the 6V6
The cathode to power valve one is the same - so the foil should be at the 12AX7 cathode end.
If it makes any difference at all, that is.
This has very low output impedance when not driven into clipping, so the outside foil should be connected to the PI end for both the plate driven and cathode driven sides.
The outside foil is not always correctly labelled in my experience, but can be identified using a oscillascope.
Whether it's subjective or not, I ..er subjectively can't say, but I'm enjoying the tone a lot better with the Jupiters than I was with the Mallorys
