Mesa boogie dual rectifier rust
richyleerichylee Frets: 15
Hey guys I'm looking to buy a Mesa boogie dual rectifier multi watt so I'm looking on eBay etc I found one that has what looks like rust on the inside of the amp. Is this normal ?
  • richyleerichylee Frets: 15
    edited May 2017
    Here is the amp in question https://www.ebay.co.uk/itm/162508058539
  • webrthomsonwebrthomson Frets: 1031
    That listing is now gone - but in a work no - it would indicate the amp has been stored somewhere humid or moist.
    It's still on eBay but won't let me copy the link
  • ICBMICBM Frets: 72413
    http://www.ebay.co.uk/itm/162508058539
    It's been stored somewhere damp. It's probably fine, but I would want to have it thoroughly checked by a tech, and I definitely wouldn't pay the normal price for it, just in case.
    Especially if it came from Guitar Guitar...
    Ok thanks lads
  • NelsonPNelsonP Frets: 3400
    edited May 2017
  • richardhomerrichardhomer Frets: 24811
    I'm sure some WD40 would soon Rectifier....
    Haha nice
  • revsorgrevsorg Frets: 880
    This nightmare repair video really put me off Boogies - they just seem so complex...
  • BintyTwanger77BintyTwanger77 Frets: 2231
    edited May 2017
    Well now I'm worried... that's where I got my RoV and it's with them for a warranty check-up now, though I did buy it at the price it was pre-hike.
    They are quite complex, but not actually that bad to work on usually, and fairly reliable in the first place so they tend not to need it very often.
    The JFET switching is a well-known problem on them though, that is true - as are those jumper cables.
  • professorbenprofessorben Frets: 5105
    NelsonP said:
    Whilst that is a GREAT price currently, it sounds nothing like a Recto, trust me I own one.
    Its more Mkii or iii in character, that mid heavy sound.
    It doesn't do the loose boomy low end wallop that a recto does, it's much tighter and thicker.
    I think the low end wallop is more about the power amp than the pre amp.
    It is, but the Studio/Mark series preamp is completely different from the Rectifier preamp too, so they sound nothing alike and still wouldn't even if you put a Studio preamp through a Rectifier power section.
    Essentially the Mark Series sound is a hot-rodded Fender Blackface circuit with the EQ pre-distortion, and a Rectifier is a hot-rodded Bassman/Marshall circuit with the EQ post-distortion. Even with the graphic EQ being post-distortion, a Mark can't sound like a Rectifier or vice versa.
  • DJH83004DJH83004 Frets: 196
    From the photos it look very much like The iron laminations on the transformer have picked up some surface rust, you do see it quite often depending where they have been stored. Regarding reliability the main issues I have come across have been channel switching faults, particularly with the switching relays, as they are a pig to get out. At least with the through plated boards you can get most components out from the component side, but alas not the relays.
  • ecc83ecc83 Frets: 1636
    "The JFET switching is a well-known problem on them though, that is true - as are those jumper cables."
    What sort of problems with the FETs IC? Do the devices themselves fail or the control systems?
    As I am sure you are aware(!) I am familiar with a range of products that use them extensively. Mind you, the mixer industry is pretty much based on FET audio switching and you don't hear of problems. IIRC the J112 is the most commonly used device, do Mesa use same?
    Dave.
    Looking in my own Mesa 'bits' bin Dave, they seem to be J175 that I have as spares, and quite a few miniature relays !
    Yes, usually J175. The transistors themselves fail - presumably they don't like being in a high-voltage valve environment. Even though they should be decoupled, some aren't entirely if other things go wrong, eg preamp valve failure with a leak to grid.
    I'm not a great fan of the switching on modern Mesa amps, I much preferred the Vactrols they used to use - although those aren't immune from failure either - but we know why they don't use them any more!
    To be perfectly honest I am beginning to not be a fan of complicated valve amps with automated switching in the valve sections at all, they often cause more problems than they solve...
