Helix is getting so much love nowadays... so I wondered, is anybody here using Helix with a Line 6 Variax guitar?
Any comments on what it performs like?
Thanks
great
my wanted dead or alive patch is genius
Yeah... we know you're great... but what about the Variax? :-)
Which model are you using?
Do you gig it?
How stevic (12 foot ninja) uses his is incredible.
I'm a luddite, wouldn't know how to be that creative.
I'm periodically gigging it depending on the gig and if I have the room for another guitar
I used it for the wedding band when I was doing that. Adding banjos 12 strings a simulated mandolins
The flexibility is amazing. You can change all the parameters with snapshots. I setup up a couple of paths. One with an acoustic IR compressor and reverb and another with a guitar amp
I put a gain block in front of each one set to zero and then switch them on and off to flip between the paths
I have snapshots for
12 string acoustic with drop D
12 string acoustic in Mandolin tuning
6 string acoustic standard
6 string acoustic DADGAD
Lester1 Standard tuning into a Badonk and a delay
Lester 1 in Open Drop C (just for fucking about)
I should probably do a little vid on it if folk are interested
@Cabicular. Thanks for the info. A video would be very interesting.
What's the JTV like in terms of 'feel'... as a regular electric guitar?
It won't set your world on fire but you won't struggle to play it.
I could tell the difference between the modelled Electrics and the Mags unless I knew I was on one or t'other. No real latency. The key to good acoustic sound with them is good EQ, soft plectrum and a gentle touch.
I would struggle to take it as my only guitar but thats more down to my own snobbery rather than anything being wrong with it
Yes... your final sentence applies to me as well, I think. I imagine a JTV would struggle to feel as resonant in the hand... as say a decent CS Strat.
Still... I might give one a try. A few dealers seem to be selling them at a bit of a discount. :-)
The new Shuriken is a bit teenage metal head for me these days but it looks to be a great idea. Maybe I'll get one and paint it.
Smeg.
Now I don't care about the silly look of it. I want it.
I suppose if you have a Line 6 Helix or even a Pod HD whereby you can pre-programme everything to change guitar and amp/cab/effects patch simultaneously, then I can see the advantages. But as a practical gigging guitar, thanks but no thanks - I'll stick with my proper guitars.
I went to see My Vitriol a month or so back, and they were both using a Variax guitar. No amps on stage, just monitors and the PA pushing the sound of the band. I couldn't see if they were using Helix.
It sounded clear, but it missed something....maybe not just volume...
or more importantly feel wrong
I just kind of treat it like Lester 1 = humbucker
strat 5 = single coil
You can also switch between Variax and mags on the Helix
My music:- https://soundcloud.com/hubobulous
