Evertune Bridges
guitarfishbayguitarfishbay Frets: 7961
Has anybody owned an Evertune Bridge guitar yet?
What are the pros/cons?
Have you found it has altered your technique when switching to a non Evertune bridge guitar?
There's still not that much choice in off the shelf models and I haven't seen a single one yet.  But the concept is very interesting to me.  I don't use a trem, but a guitar that always stayed it tune would be amazing.
  • Jack_Jack_ Frets: 3175
    There's one obvious con, it's really fuggin ugly.
  • guitarfishbayguitarfishbay Frets: 7961
    edited May 2017
    That doesn't stop people buying Telecasters with Bigsbys
    It means you might have to play one of these things: :)
    Devin Townsend signature Framus guitar with EverTune Bridge
  • ToneControlToneControl Frets: 11928
    I have 2
    very good
    weighs a bit
    fiddly to set up
    stays in tune on higher fretted chords (corrects for extra unintentional pressure from your fingers)
    very tight rhythm sound - as if using much heavier gauge
    when bending, feels like 1 or 2 gauges higher
    Thanks @ToneControl ;
    So do you use your normal string gauge or go lighter? I'd like to go lighter actually, I think thinner strings have more attack and clarity but I go heavier on sound strings for practical reasons. Since I tune to a low B I'm using a .064, which sounds woolly quickly compared to the other strings. A 56 sounds great but poses a lot of tuning issues the way I play. I don't like the feel of baritones
  • ChristopheChristophe Frets: 62
    Oooh spaceship :)
    the bass strings don't flop about anywhere near as much, there's no slight change in pitch just after the pick attack, but I'm not sure what 64 = B would work like
    I use 9-46 on everything electric (including these) except my real baritones (30 inch, etc)
