Why aren't Strymon PSUs earthed?
mellowsunmellowsun Frets: 2422
i was getting terrible mains hum with my Big Sky earlier, as I was recording direct to a battery powered Tascam, so there was no earth.
Only when I switched the two-pin Strymon PSU for a 3pin earthed PSU did the hum disappear.
Why do Strymon supply garbage PSUs with their high end pedals?
  • SporkySporky Frets: 28546
    Because the standard use involves a grounded amp, in which case a non-grounded PSU will likely mean less noise.
  • mellowsunmellowsun Frets: 2422
    True, but it's not the only use. Strymon's YouTube channel shows the BigSky used with synths and also the emulated out recorded direct.
    i suppose a PSU with an on/off earth switch is too much to ask, but.
